HI, the Desire isnt mine but its my girlfriends, shes having problems with the notification sounds. It will play the correct sound when you plug it into the charger or USB, but not when she recieves an SMS which is obviously really annoying. I have tried updating the software for her using the HTC over the air update, its running 2.1. I dont have any other details of the software at hand, but if anybody knows how to sort it i would be very grateful, also the ringtone works fine.
Thanks in advance
Paul
Thanks in advance
Paul
