I've figured out how to change my ringtones with downloaded ringers but I can't figure out how to use a downloaded notification tone, only the notification tones that came with the phone is there any way to make this happen?
there's a folder on your sd card labeled 'notifications'. drop the sound file in there and you should be good to go. same thing for ringtones, there's also a folder for that on your sd.
