Help Notification sounds - Hierachy and Issues
Skibumtx
Hello all,
I'm having trouble getting notification sounds working and wondering if anyone might be able to explain which settings might take precedence in situations where an app may be trying to send a notification. The issues show up in the following situations:
1) I'd like to stop the phone from issuing a notification sound whenever the SD card or internal memory is mounted/unmounted. This seems to be under the control of the main system notifications (Settings -->Sounds--> Notification Ringtone) but I've noticed that the system seems to reset my selected sound to a default trill if I try to use a Zedge ringtone, or a silent ringtone. It also seems that some of my app notifications are over-ridden by this "system notification". Does the system notification always override the app notification? Is there a way to silence the system notification and still hear the app notifications?
2) In order to get the phone display to show what I want I end up using a combination of Calengoo and Agenda Widget (plus) and the default calendar app is still on the phone. Which application should I use to set up notifications; Agenda Widget, Calengoo, or the default calendar app?
3) I would like to get my notifications to repeat until acknowledged but can't seem to make it happen. Anyone know how I can do this?
Thanks,
Ski
