Help Notifications volume turning itself down
Nebs84
I recently updated the software on my Samsung Galaxy S3 to the latest Android version (4.3). Ever since then, whenever I switch my phone to vibrate or mute, and then switch back to normal sound, the Notifications Volume stays muted and doesn't go back to its original setting.
Obviously this is quite frustrating as I often don't hear when I get a message. I have tried restarting the phone, and also installing Volume Control + app but to no avail. Any suggestions?
Have you tried a factory reset? Though it's a pain in the butt, a factory reset can fix a lot of issues. There may be someone here with a better suggestion, but I haven't tried 4.3 do I'm not too sure if it'll fix the volume issue you're having.
OK so I did a Factory Reset, and other than wasting 3-4 hours of my life to get my phone back to the same shape as it was before the reset, it did nothing to solve my problem with notifications being muted after the phone has been on silent for a while. Can somebody help me please?
I'm rooted so I'm not entirely sure if this is just a feature of my ROM, but there normally is an option to link the ringtone and notification sounds, make sure that is linked.
Well ignore that, I didn't look at your screenshot...
How do I check if my ringtone & notifications are linked?
Sorry to give you a bit of hope there, but realized my volume screen is different because of the rom I'm using. After I went back and noticed the picture in your post, you don't have the checkbox to keep the volumes linked.
At this rate ( I even googled a bit ) only way I would know how is to install another ROM. Sorry :(
OK well, I Factory Reset the phone again (from Recovery mode), tried to reinstall the firmware but it didn't let me, so I started using the phone after just a simple Factory Reset and it works fine. I haven't installed any apps yet which makes me think it was an app that caused the problem. Thanks everyone who posted on this thread!
