Help Notifications volume
Settings -> Sound -> Volumes. Although on previous handsets, I was able to set the ringtone/notification volume separately, it doesn't look like you can do that with the One X.
I'm pretty sure in ICS sounds volume is lumped only into "Ringtone/Notifications," "Alarms," and "Media," there is no fine-grained control on a per-app or per-notification type any longer (except Alarms). So you are correct and it is an ICS thing.
OP try opening the app you want louder, then hold the volume up button while in that app to max it out- but it will bring the volume of all ringtones and notifications up to that level...
