Help Notifications while using phone
kcsaarts
Just got a Sprint Galaxy S ii. Problem is while on the phone the text notifications come through and the person on the other end of the call can hear it as well, everywhere i read here and other places it says to go to settings, call settings, call alerts to change it.......problem is when I get to call settings there is no option for call alerts, I have been through this phone up , down and sideways and still can"t find any place to change that.
Are you using a 3rd party messaging app?
Could the option to disable the in-call notification be located somewhere in there?
If your phone is on ICS, it is a "feature" and it will not go away. At least, I haven't found any way to make it stop yet, nor I have I seen a solution on any other forums except for the root/ROM method.
Ok so I've made this work by using Handcent SMS which I prefer to use over the stock messaging app. Here is what you do:
-Go into the stock app, settings, select ringtone and silence the notifications, also uncheck the display notifications in status bar option.
-Go into handcent and choose your ringtone.
-In handcent under notifications you can choose weather to alert you with a beep or vibrate during a call, check as you please. FIXED!
Your phone will no longer alert you in the middle of phone calls unless you want it to!:)
Now what in the heck is stock app or handsent??? Do i need to go to the playstore n dl both apps????
