notifycation flash
Yes it is but i dont know if you want it . This app will wipe your battery dry . Yes i said wipe your battery dry.
Thats the problem they work with some devices and dont work with others . Feel free to try others like
Flashalert
Flashalert pro.
Or just enter Flash alert into the playstore search bin.
Some phones may need root so you can update builddot prop. but in the end this may wear out your flasher and may also break your camera .
