Downloading now too...I may flash the factory image to have a nice clean install.
I ended up being lazy, and did a 'dirty' flash. I flashed everything except userdata (didn't want to restore my data/apps). So far, it is working without a problem. But I agree - a clean install is probably safer.I agree. A clean install is the only way to go.
You should. Worst case, if there are issues, just flash stock recovery, and then, flash TWRP.Sooooo, if I were to open the zip and remove recovery.img and flash. Would I then have factory Nougat with TWRP installed?
Isn't that on 7.1?So I went ahead and did the OTA last night (I wont have time to flash it till the weekend.) I do have 7.0 now but no pixel launcher? It was a very weird OTA - I went ahead and factory re-set afterwards to clean everything up but still came back with the same old launcher. ????
I've stopped flashing TWRP - I just boot into TWRP, and flash supersu. I stick with the stock ROM/kernel, so no need for TWRP after that. I just need adaway to block those script popups about malware
Well for me ... it's probably as much about the "clean install" as Nougat ... the old N6 had gotten a little laggy. After clean install it's sharp again. As far as features it's little things for me. I like the new multi task look and feel, the new pull down menu is MUCH better, you can rotate the home screen now (landscape) OH and I have experienced really good battery life.So convince me to go all nougatty.
so you cats are installing this THEN doing a factory reset?
