Apps NullPointerException AlertDialog.Builder
Hi everyone :)
I've been looking into this for a couple of hours and changed the code quite a few times however the nullpointerexception error is still appearing
The problem is occuring when my "WorkOn" class calls another class called "Dialogs"
So this is my WorkOn Class
Java:
public Context context = this;
    Dialogs saveDialog = new Dialogs(context);
//constructor
    public WorkOn(Context context) {
    this.context = context;
    public void OnTime(View v) {
            saveDialog.WorkOnSavedDialog(v);
This is my Dialogs class
Java:
public class Dialogs extends AppCompatActivity  {
//constructor
public Dialogs(Context context) {
public void WorkOnSavedDialog(View v) {
    AlertDialog.Builder alert = new AlertDialog.Builder(Dialogs.this);
    alert.setTitle("Work On File Saved");
    alert.setMessage("[Displaying for Test] Work On File Saved");
    alert.setPositiveButton(android.R.string.yes, new DialogInterface.OnClickListener() {
                public void onClick(DialogInterface dialog, int which) {
                    // continue with delete
    alert.setNegativeButton(android.R.string.no, new DialogInterface.OnClickListener() {
                    // do nothing
    alert.setIcon(android.R.drawable.ic_dialog_alert);
    alert.show();
The nullpointer excpection is happening because of
Java:
do you have any idea why this is happening?
You need to post the stack trace from your Logcat output
My logcat is
Java:
08-01 10:20:36.156 5739-5739/geepool.workonworkoff E/AndroidRuntime: FATAL EXCEPTION: main
        java.lang.NullPointerException
        at android.content.ContextWrapper.getApplicationInfo(ContextWrapper.java:132)
        at android.view.ContextThemeWrapper.getTheme(ContextThemeWrapper.java:65)
        at android.support.v7.app.AlertDialog.resolveDialogTheme(AlertDialog.java:111)
        at android.support.v7.app.AlertDialog.access$000(AlertDialog.java:70)
        at android.support.v7.app.AlertDialog$Builder.<init>(AlertDialog.java:291)
        at geepool.workonworkoff.Dialogs.WorkOnSavedDialog(Dialogs.java:25)
        at geepool.workonworkoff.WorkOn$1.onClick(WorkOn.java:99)
        at android.view.View.performClick(View.java:4084)
        at android.view.View$PerformClick.run(View.java:16966)
        at android.os.Handler.handleCallback(Handler.java:615)
        at android.os.Handler.dispatchMessage(Handler.java:92)
        at android.os.Looper.loop(Looper.java:137)
        at android.app.ActivityThread.main(ActivityThread.java:4745)
        at java.lang.reflect.Method.invokeNative(Native Method)
        at java.lang.reflect.Method.invoke(Method.java:511)
        at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:786)
        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
        at dalvik.system.NativeStart.main(Native Method)
thanks once again :)
