Apps NullPointerException on SQLiteDatabase.query
Booyakha
Hi there,
I got a NullPointerException when I tried to get all the agenda that are recorded in my SQLite database.
The insert works well, I create a Toast with the ID which is returned, and it increment normally.
Code:
public List<Agenda> getAllAgenda() {
          List<Agenda> agendas = new ArrayList<Agenda>();
          Cursor cursor;
          try {
          cursor = bdd.query(TABLE_AGENDA,
                 new String[] {COL_ID, COL_INTITULE, COL_DATE, COL_HEURE}, null, null, null, null, null);
                if ( cursor.moveToFirst() ) {
                   while (!cursor.isAfterLast()) {
                      Agenda agenda = cursorToAgenda(cursor);
                      agendas.add(agenda);
                     cursor.moveToNext();
                cursor.close();
          } catch (Exception e){
             Log.d("AGENDA DAO", e.toString() );
       return agendas;
For information, I don't call getAllAgenda() in my main activity but in a secondary one... with this code :
Code:
public class ListeActivity extends ListActivity {
   private AgendaDAO agendaDAO;
    private SimpleCursorAdapter dbAdapter;
    @Override
    public void onCreate(Bundle savedInstanceState) {
        setContentView(R.layout.activity_liste);
        ListView listView = (ListView)findViewById(android.R.id.list);
        agendaDAO = new AgendaDAO(this);
       agendaDAO.open();
        try {
           List<Agenda> agendas = agendaDAO.getAllAgenda();
          Log.d("NB AGENDA",Integer.toString(agendas.size()));
           ArrayAdapter<Agenda> adapter = new ArrayAdapter<Agenda>(this,
              android.R.layout.simple_list_item_1, agendas);
          listView.setAdapter(adapter);
        } catch(Exception e){
           Log.d("EXCEPTION",e.toString());
        agendaDAO.close();
Any ideas ?
Thanx a lot !
Sorry the Exception isn't a NullPointer but this one :
Code:
java.lang.IllegalStateException: attempt to re-open an  already-closed object: android.database.sqlite.SQLiteQuery (mSql =  SELECT ID, Intitul
Once a database is closed, a new instance needs to be created in order to reopen it. You can't just re open a closed database. Another option is to just leave the data base open until the app is shut down.
