blissandroid
Hi
I'm working on my first non-trivial android project.
In this project I use alot of NumberPickers.
I use the xml file to add NumberPickers to the Views.
I noticed that sometimes the NumberPickers are presented with a Plus and Minus above and below the number respectively, and sometimes the NumberPickers are presented with up and down arrow above and below the numbers respectively.
I cannot see the code that specifies that 'type' of numberPicker to be used in my code.
1.) How do I specify that I want a numberPicker with a plus/minus or up/down arrow?
2.) I noticed that the plus/minus numberpicker does not allow scrolling but the numberpicker with up and down arrow allows for scrolling.
How do I ENABLE scrolling in the numberPicker?
Thank you very much for the help
