Help O2 Picture SMS not sending...
This may be a stupid question.
I tried to send a picture using SMS to someone last night, and it wouldn't send.
Just kept coming back with "Generic Network Failure".
I also couldn't receive any picture messages.
Any ideas anyone?
TIA
[EDIT]
Android Version: 2.2
Network: O2
Taskiller Used?: Nope
[Optional]Are You rooted & which Rom: N/A
[/EDIT]
Any ideas anyone?
TIA
[EDIT]
Network: O2
[/EDIT]
Does anyone have any ideas on this?
Not very long ago, I noticed that I couldn't send/receive MMS either. I tried contacting O2 with no success (still waiting a response over a month now! lol).
Anyway, I sorted it and it's probably your APN settings too.
Try these:
Name: O2 Pay Monthly MMS
APN: wap.o2.co.uk
Proxy: 192.113.200.195
Port: 8080
Username: o2wap
Password: [password]
Server: <not set>
MMSC: http://mmsc.mms.o2.co.uk:8002
MMS Proxy: 192.113.200.195
MMS Port: 8080
MMS Protocol: WAP 2.0
MCC: 234
MNC: 10
Authentication type: none
APN Type: <not set>
It worked for mine, at least. If it doesn't work for you, try a google search as there are other very similar settings out there they may work.
Try these:
APN: wap.o2.co.uk
Port: 8080
Username: o2wap
Server: <not set>
MMS Port: 8080
MCC: 234
MNC: 10
APN Type: <not set>
Aaahahaaaa!
Great, thanks - at least I know what to search for now!
Thanks again
:D
Think you'll need to add the MMS settings too....
  1. Press the Menu key
  2. Tap Settings
  3. Tap Wireless & networks
  4. Tap Mobile networks
  5. Tap Access Point Names
  6. Press the Menu key
  7. Tap New APN
  8. Tap Name then tap the text box and enter O2 Pay Monthly MMS then tap OK
  9. Tap APN thentap the text box and enter wap.o2.co.uk then tap OK
  10. Tap Proxy then tap the text box and enter 193.113.200.195 then tap OK
  11. Tap Port then tap the text box and enter 8080 then tap OK
  12. Tap Username then tap the text box and enter o2wap then tap OK
  13. Tap Password then tap the text box and enter password then tap OK
  14. Skip past Server as this is preset as Not set
  15. Tap MMSC then tap the text box and enter http://mmsc.mms.o2.co.uk:8002 then tap OK
  16. Tap MMS proxy then tap the text box and enter 193.113.200.195 then tap OK
  17. Tap MMS port then tap the text box and enter 8080 then tap OK
  18. Tap MCC then tap the text box and enter 234 then tap OK
  19. Tap MNC then tap the text box and enter 10 then tap OK
  20. Press the Menu key
  21. Tap Save
  22. Tap your new account so a green dot appears next to it
  23. Press the Back key four times to return to the standby screen.
It might be a provider issue. I was having the same problem at the weekend (O2 also), I did nothing at all and the next morning it was all working again.
