If you text the word ACTIVE to 2020, o2 usually send a file to the phone with all the settings for you. If this doesn't work, all the settings are available here : MMS Picture Messaging Information
s_flinn: in the gallery, select the picture that you want --> select share --> select messaging and there you go If you look at the option, you can share it to quite a number of apps.
