This has been patched by @vm03 in the latest commits. Any build after 5/13 does not need this patch. Although other ROMs might still need this.
[UAYOR] means Use At Your Own Risk.
VERY BIG DISCLAIMER:
I, LitrosNub, or anyone else. Are not responsible for doing this fix and brick your device, the fix may cause some security problems and if your device gets destroyed by a hacker. That's your problem for doing this TEMP fix. Not ours. Thank you for reading this.
IMPORTANT ANNOUNCEMENT
If you get Force Closes when trying to access Security or Lock Screen on Settings, use this method. It works too!
Step 1:
Go to Mount:
Step 2:
Enable System Partition, it should show an X in the tickbox. If its already there, proceed:
Step 3:
Click on Advanced:
Step 4:
Click Terminal Command:
Step 5:
Scroll Down to System:
Step 6:
Find Lib:
Step 6:
Find HW:
Step 7:
Click select:
Step 8:
Type LS then click the enter:
Step 9:
Type rm keystore.msm8610.so click enter:
Step 10:
Reboot, enjoy the lockscreen and no more Force Close!
Special Thanks to:
@Bad_MOFO_33 (for finding the method)
@zlaja84 and @vm03 just for being awesome
@DevMyAndroid tagging me all the time to try out new methods
Step 1:
Go to Mount:
Step 2:
Step 3:
Click on Advanced:
Step 4:
Step 5:
Step 6:
Find Lib:
Step 6:
Find HW:
Step 7:
Click select:
Step 8:
Step 9:
Step 10:
Special Thanks to:
You learn everyday, I guess...
