Previously had this problem with my Droid Razr after it updated to Android 4.1 and continue with my stock Verizon LG G2 which runs Android 4.2.2. It has only happened (on both phones) at work. I work in a factory and essentially can't use my phone unless I am on wifi.
Problem: When trying to connect to the company "Public" network it just continuously displays "obtaining ip address". My Razr connected just fine before the update and now my G2 does the exact same thing.
I have tried: I have searched and searched and searched the internet. Trying to check and uncheck every option suggested on the phone. I have installed numerous wifi fixing apps including (wifix and a few others). Obviously I cannot just run in Static IP mode since I cannot get all the necessary information from my work wifi network. I WILL NOT root my phone. The only advise I have gotten from verizon or phone manufactures is that it is a problem with the router and that you need a new one. Obviously I cannot do this since it is a giant wifi network at work.
I am at my wits END with this!!! PLEASE HELP!!!!!!!!!
I'm pretty sure if I could find the router in this dirty labyrinth I would have already reset it myself! I talked to another tech savvy employee who has the EXACT same issue with their (German) X1. Running Android 4.2.2 and gets the obtaining IP loop on DHCP and connection but no internet access on static IP settings. And like I have said before my coworker with an iPhone 4s connects everyday with no problem. I am at the point I am just going to give up and hope that KitKat might solve the wifi issue. If you search the internet, it is not a rare problem at all. Hopefully they have gotten wind of it and changed their status of "Buy a new router" which they released shortly after the 4.2.2 update. *sigh*
