Root obtaining ip fix (wifi)
theisonews
i dont have access to the router. so i found a work around. from the market download and run fxr wifi fixer. it will ask you to reboot. dont do it. next go to your wifi screen and go to menu advance and click static ip. the enable your wifi. let it scan a few times. then disable wifi and uncheck static ip. the re enable wifi. and connect to the desired network. successs.
also try this.. enter the wrong password to the network. it will authenicate and fail. then try again with the right password.
