the same thing exactly lolWhat are your OC settings? I am currently running the kernal that comes with minimal android, as for settings I'm doing 1.5 ghz Max 122 min with the smartassv2 governed and sio scheaduler. What are you using?
WOW impressive, hows battery on that? do you lag? Or are you running smooth?576Mhz Max
61Mhz Min
Undervolted
Interactive & SIO
yea thats crazy man how do you manage that!576Mhz Max
61Mhz Min
Undervolted
Interactive & SIO
Smooth, it's my daily. I does game often too, no lag. The only game that lag was Blood & Glory at random.
[ said:(censored) []Austrie said:Maybe your phone cant handle it, try to up each value by 50 and if you still reboot. Then up by 100[I said:[] (censored) [][/I]]Austrie said:Interactive & SIO[ said:(censored) []]WOW. ur MT can handle that wif no lag? wow. mine lag. only can do 768mhz. wats ur governor n io? n if it was up to 768mhz wat would the voltage b?Austrie said:61Mhz - 500v[ said:(censored) []]yea thats wat i mean. wat r ur settings for them?Austrie said:I don't edit all the frequencies, i just edit my frequencies for the frequencies I use( 576Mhz - 61Mhz)[ said:(censored) []]hi im sorry if im asking too much or not suppose to but what r ur settings for undervoltage?
122Mhz - 525v
184Mhz - 550v
245Mhz - 600v
368Mhz - 625v
460Mhz - 650v
576Mhz - 700v
61Mhz - 500v
122Mhz - 525v
184Mhz - 550v
245Mhz - 600v
368Mhz - 625v
460Mhz - 650v
576Mhz - 700v
6##Mhz - 725v
768Mhz - 750v or 800v(maybe 775v)
unfortunately, putting those values causes me to reboot. why is this?
Okay so if I were going up to 1.3ghz, I would follow your settings in Incredicontrol then go up 50 or 100 each step?No it doesn't undervolt automatically, it is still using stock volts. I underclock with no-frills cpu & undervolt with Icredicontrol(Incredicontrol had a update so you don't need no-frills cpu anymore).
Somebody had PM'ed me, this was the conversation;
