odd battery issue
Bramsy
Android Expert
My battery was lasting 2 hours at most for the past 2 days..
Yes I removed recent apps that could cause this and no I haven't done major Rom/theme changes...
I know batteries go bad but this bad this drastically?
not to say that its impossible but it would be rare! i dont think it would go bad that quick unless something happened to it. did you experience declining performance or abrupt? did you overheat it perhaps while charging?
ever noticed when you reboot your phone your battery percentage changes? that's a false reading. i delete mine if i have changed roms frequently. it helps.
let y our phones battery go completely dead then plug it up to your wall charger for a brief minute. reboot into recovery and go advanced. wipe battery stats and dalvik cache (only because its right there). let your phone completely charge undisturbed. run it all the way back down before charging and charge again undisturbed. it may take a few days to rebuild your stored battery stats but i saw a great improvement.
