Odd change when connecting to PC
nitramus
Before when I connected my N5 to the PC (windows 7) it would be added under "devices with removable storage" and called Nexus 5 and would just open like any other drive.
Noe for some reason it is added under "Portable devices" and still called Nexus 5 but now also has "portable media player" underneath.
I know about MTP option in apps/usb coputer connection and it was always on but never had this. Before when I connected it to the PC I would only have the notification "usb debugging connected" and now I also have "connected as media device.
I did not do any changes but since this happened the only thing I did was update the usb drivers using sdk manager.
Thanks
Also I have a shared folder on my PC that I access using es file explorer and since then the app can not find my PC when doing a scan.
