korywiesner
Today I decided to install the tweaked V3 W/Take 5....
Started to update rom and couldn't get phone to connect......
It would say debugging was working but nothing in ADB > Devices.
Long story short....A few hours of fiddling...Took out SD card and it started working....Formatted the card....
Flashed rom.....
Worked a few times and now nothing.
Every now and then when i reboot the phone it will work. It only works for 20 minutes or so and then stops. I get the USB Connected Prompt and when I press it (waiting for the Mount window) It goes back to nothing.
Any Ideas. I know the drivers are fine on the laptop.
What am I missing.
UPDATE: I cleared the dalvik-cache.........problem went away. Go figure. Phone works perfectly.
Flashed rom.....
What am I missing.
