Help Oden 1 click - Rogers canada phone
Shortelz
So after having tons and tons of problems trying to update to 2.2 using samsung kies, someone told me to use odin to get to 2.2. It worked fine although it says AT&T when it boots and comes with ATT apps. First of all, will this cause any problems to function normally on rogers canada network. Second, Is there any way I am able to go back to my normal Rogers Canada 2.1 or 2.2 firmware? I dont have a backup or anything of the firmware... :s
Yes it is possible I have done it a couple of times. You need to use the rogers rom which can be found on xda. I would link you but I'm sending this from my phone, just do a search on the xda, very easy to find.
