andriodadmirer
HEY THIS IS ANDROID ADMIRER WITH YET MORE GOOD NEWS
WE NOW HAVE AN ODIN FLASHABLE METRO PCS KITKAT 4.4.2 FULLY STOCK ROM HERE NOW
AS LONG AS YOU CAN STILL GET INTO DOWNLOAD MODE YOU CAN NOW UNBRICK YOUR METRO PCS LIGHT
****************THIS FIRMWARE IS NOT ROOTED AND DOESN'T INCLUDE TWRP****
Instructions
Extract (unzip) the firmware file HERE IT IS
http://www.mediafire.com/download/hthd2agm3852ksz/T399NUVUANK3_T399NTMBANK3_TMB.zip
DOWNLOAD ODIN3 V1.85 HERE
http://www.mediafire.com/download/bm8wqnvgdujxu97/ODIN.zip
Extract Odin ZIP file
Open Odin
Reboot Phone in Download Mode (press and hold Home + Power + Volume Down buttons)
Connect phone and wait until you get a blue sign in Odin
Add the firmware file to PDA
Make sure re-partition is NOT ticked
Click the start button, sit back and wait few minutes
AFTER YOU DO THIS YOU CAN NOW DOWNLOAD TWRP 2.8.4.0 HERE ( ALL THANKS TO UNJUSTIFIED DEV FOR THE TWRP !!!!)
http://www.mediafire.com/download/klokhec5b3uw1yn/openrecovery-twrp-2.8.4.0-gardalte.tar.md5
INSTRUCTIONS ON FLASHING THIS......
1. OPEN ODIN
2. CHECK THE PDA BOX CLICK PDA AND SELECT TWRP AND SELECT OPEN
3. SELECT START
THERE YA GO
PLEASE READ!!!!!!!!!!!!!!!!!
*************I SHOULD MENTION THAT FOR ME TO FLASH THE ROM ODIN TOOK A MINUTE TO PROCESS EVERYTHING
BUT DON'T PANIC IT WILL GO THROUGH JUST FINE ********************
AFTER YOU FLASH THIS YOU WILL HAVE TWRP AND THEN YOU CAN FLASH MY CUSTOM STOCK ROM THAT HAS ROOT ALREADY INSTEAD OF TRING TO ROOT THIS ROM
I HOPE THIS HELPS ALOT OF YOU THANKS !!!!!
Instructions
Open Odin
1. OPEN ODIN
3. SELECT START
THERE YA GO
