Odin (help)
Sanchez67
Well after using odin on my Samsung Galaxy indulge Metro pcs (SCH-R910) , My Setting are messed up. Can someone help me find the roms or bios or any other files i could use to set my phone back in order ?
Specs:
Hardware Version : Unknown
Model Number: Sch-R910
Firmware Version : 2.2.1
Baseband Version : Unknown , LTE : SCH-R910.ED15
Kernel Version : 2.6.32.9
Build Number : SCH-R910.EE07
And now my phone is in airplane mode alot. It keeps shutting off unless im running music or its on the charger. Can someone please help me fix the unknowns "MY hardware version , Baseband Version" and help me update my phone? Thx For reading and your help.
You misused Odin by flashing using the phone instead of the pda button.
Basically, you erased your phone's modem files.
To fix this, extract the tar from this and flash it in Odin, and make sure to stay in Pda next times you flash your phone.
http://k0nane.info/rom/eg06modems.rar
And please say thank you to k0nane, since those are his files.
If this works would that allow me to upgrade my modems from EA29 and EA17???
When I did a warranty exchange I got a phone that never got its modems upgraded!!!
i completly lost ma phone settings.after i used odin and i suddenly closed odin btween its going on...now hen am swithcing the phone ..i can only see a pic of a phone and a pc and an "!" between them.plzz helpppppppppppp @tiede
Your settings are long gone. But to get your phone back to normal, all you need to do is restart the process and let it finish this time. ;)
If Odin does not want to work for you, use the heimdall package instead.
