office administrator
MELLIZAH
hello ( :help,,, want to connect my android cell phone to my pc, but do i need a software or can i just plugg in the usb cable?i want to view all my stuff on a bigger screen thats why i am trying to connect my phone to my pc? is that posibble?thank you kindly (=
Hello, welcome to the forums.
Can you tell us what kind of device you are using, that way we'd be in a better position to help.
As far as I'm aware, there isn't the capability to do that on a lot of (maybe all) handsets at the moment.
Welcome to the forums!
If you want to access your files on your SD card from your PC, connect your phone via USB to the PC, and pull down the notification bar (the white/black bar at the top of your screen) and select Mount SD to PC (something like that)
Apologies, I thought you meant you wanted to view your Phones screen on the PC. If you're just looking at files etc, then yes, shadownintys suggestion is most certainly viable. :)
