Hi everyone. I was just trying to get a compatible format to edit documents both on my windows pc and on the tablet. I experimented Documents to Go (preinstalled on the device).
But when I edited the "Documents to Go" files on my pc, on which I use free softwares like Open Office, Libre Office, etc, they were not compatible on the tablet. It says it is a "non-microsoft office file"...
I then solved the problem just using Kingsoft office which is ok for .doc edited by Open O and Libre O.
ALSO you can just edit the document with Kingsoft O and it will be MAGICALLY compatible with Documents to Go too! I personally prefer Documents to go because it is really faster than Kingsoft Office so you can use it with painfully tablets like mine
I wish this will helpful to you. Bye-Bye
