OfficeSuite and Google CloudPrint
bruce73
I can't get docs created with OfficeSuite to print via CloudPrint, either from within the OfficeSuite app or from the Cloud Print app available from the Store.
Is this simply not supported with OS (even though you can set up the printer)?
Just a generic "Error" on my Google print page in Chrome that tells you nothing.
I can print Cloud Print's test page, TXT files, and files exported from Dropbox. I can also print DOC files using Brother's Android app.
Update: I installed Kingsoft Office and had no problem printing a DOC via Google Print, so it must be an OfficeSuite issue.
