OfficeSuite Pro user manual?
mary896
Howdy,
I've searched all over and can't find a user manual or any real help for understanding everything OfficeSuite Pro has to offer. I've tried a couple of scary sites that claimed to have a downloadable manual...nope. There are just a few things I need help accomplishing with this app! Ugh, anyone know where I can find this info. or manual?
Thanks and cheers!
Mary
(asus tf700 & razr maxx)
OfficeSuite Pro is a great app, but the lack of user manual has been a common complaint. As of the latest update (v7.0.1174), there is now a User's Guide provided (in PDF format).
I have version 7.0.1186 with the pdf.
I can see how to print it but would like to forward the pdf to my laptop to make it easier to study i.e larger.
I have a Galaxy S2.
How can I find where the pdf is stored on my S2?
I have a Galaxy S2.
That's a problem with ALL Android apps, as far as I am concerned.
I usually connect my S2 to a usb port on my desktop, and then use the file seach in Windows Explorer to try snd find a file name I know that was generated by the app. It doesn't always work, however. Give it a try.
I would be interested in knowing if Android has established any guidelines for app development with regard to file/folder usage while the app is executing.
Thanks for the info Mr Lucky, I got so excited thinking FINALLY, a user guide! But no. Can't find it. Stupid PDF. Shoulda gone with an apple..? Ugh. I just wanna use officesuite!
Just go to the Home tab and you'll see it (lower-right in screen-shot).
:o
Can I blame my age? Or my bad eyesight?
Thank you Lucky, your help and efforts are enormously appreciated.
Cheers!
Mary
:smokingsomb:
Howdy,
Thanks and cheers!
Mary
Thanks very much for the manual question and answer! However, how do you move Word documents into and out of file folders???
