Lokifish
Official USSD hack list of immune and unsafe ROMs
This will be the official list for ROM's and browsers affected by the USDD code issue and instructions on how to patch it til an official fix is released. Please follow the following steps;
- Visit the following link using your phones browser USDD test page
- If your MEID info is shown on the screen then the ROM you are using is affected! Download and install TelStop from the Play Store.
- After you install the TelStop app visit the test page again. You should now get a "Complete action using" popup with TelStop listed. Select TelStop. You will then receive a warning that this is likely a malicious code.
- If your MEID info is not displayed then you are fine.
- Report What ROM and browser you used and what your results were.
Source- PCWorld
Affected ROMs (I'm thinking all ICS and older based ROMs are most likely affected unless they are patched)
Stock 2.3 (all releases, all phones)
CM7
Imperium Initiative
peetr's Hybrid
MOF.2.3.5.ish
CM9
Unaffected ROMs
Th3Bill's Jellybean based ROMs (thanks Th3Bill for getting back to me so quick)
Affected Browsers
Stock
Firefox
Opera Mini
Maxthon
Safe Browsers
Opera Mobile gives prompt "Loading of external frame source tel:*%2306%23 suppressed (click to view)"
