Mredjay0
The files attached have been verified to be clean.
I take no responsibility if you break your phone in the process. I know that I have not posted much on this forum, but I really wanted to repost everything that I have come across and put it into ONE nice post that other Z987 owners can find easily.
This WILL give you Root access.
This WILL void your Warranty.
I WILL not be responsible if you break your phone.
Again...
I take NO responsibility for finding this method.
STEP 1.
"kmt5150"
Here it goes!
ROOTING METHOD FOR BUILD Z987V2.3.15, 5.1 LOLLIPOP, CRICKET STOCK SOFTWARE
I'll be outlining my exact process that gave me this wonderful gift. Toy around with it if you want
1. Install SRS Root from the Root Files.zip attachment to this post. Run the All Methods option (it will fail, don't worry).
2. Make sure your Google Play isn't set to auto-update for this next process. It seemed to help me.
2. Install Kingoroot from the Root Files.zip attachment to this post. Decline the yahoo malware search bar ****. Run Kingoroot. While it's running, make sure Google Play is set to NOT auto-update.
When Kingoroot reaches 53%, let it sit for about a minute, then reboot the phone. Allow it to start and unlock your screen as soon as you can, to allow continuation. Cover and let simmer until you reach 100%
Congrats! You've achieved root!
STEP 2.
"Masterchief87"
I used terminal emulator to enter the "reboot disemmcwp" command on my zmax z970 and it has persisted through countless reboots, dirty flashing multiple BrokenOS ROM updates, and clean flashing the latest update last night. I wiped system and did a factory reset before installing the newest update of BrokenOS and once the ROM booted up I still had system rw access without a switcher.
Running the "reboot disemmcwp" command should disable the system write protection INDEFINITELY until you use the other command to turn it back on. Also, I don't think root is needed for the command to work even with terminal emulator. It certainly wasn't needed in my case.
All I needed to do was install terminal emulator, open a terminal, and without ever requesting or granting root access, run the "reboot disemmcwp" command. It did not require root and it is still working after several days, dozens of reboots, and a factory reset.
Again, these are NOT my files, nor did I come up with this method for rooting. I am only compiling the information and presenting it to other Z987 owners for easy access.
Again...
STEP 1.
"kmt5150"
Here it goes!
STEP 2.
"Masterchief87"
