virusbetax
Ive been having lots of trouble with galaxy ROM so i decided to switch to take 5 or microhaxos. i loaded up everything installed all drivers. i first started with take 5 and i began ODIN. the Odin loaded perfectly until it reached system downloading the Odin bar stopped downloading i freaked out so after the normal 6 minutes i disconnected and a cartoon with an arrow to a comp showed up after battery pull and boot. i tried odining again with the original which took 12 minutes and finally worked. after that i tried to install take 5 again but same result. After two more times my phone booted up but got got stuck in boot loop. i disconnected before timer stopped but i disconnected when it say closed serial port rebooting. after recovery mode and restoring it still is stuck in recovery mode! someone please help!
