OI Safe Help!
bobgeorge
Member
Hello,
I had a Samsung Galaxy 2 and was using OI Safe to store all my passwords. I was doing backups to my sdcard.
Yesterday I got a new Samsung Note 3. I put in my sdcard and loaded the app OI Safe but it cannot find my password data file.
Thanks for any help you can provide!
bg
When you install the app, it installs with a blank file. Instead, put the SD card back in the 2, use Helium to back up both the app and its data, then restore the app and data on the 3 (After you install Helium on the 3).
Thanks for the tip. Only issue is that I turned in the phone to Best Buy for $75
