Help OK, I am in a huge pickle..nexus 7 broke, how do i...
bosox2k1
My screen cracked and the touch is now broken, can't unlock screen or do anything touch related. I am sending it back to square trade but i want to erase all this stuff...I tried plugging it in my Macbook, but it says the screen has to be unlocked first....
need help!
If you're worried about it being refurbished they'll very likely wipe the entire device. When I sent my Flyer in to be fixed, it was completely wiped.
Could be, there is one hat you can see the indent but it isn't drilled through, that may be the reset. I forget but it definitely has a reset, may need to remove the back to access it. Saw it on that video, just don't have the URL handy.
I searched it and can't find any link that states there's a pinhole hard reset. Thanks thought.
Been trying to get in touch with square trade the past two days, but have been put on hold. Maybe I will try to use ADB and return it to stock to wipe everything....that seem plausible?
