Ok now I need troubleshooting
mwl1119
Android Expert
After making a phone call my phone will not go into sleep mode without pressing the screen lock and the screen lock is gone completely. This is the second handset to do it. I am running warheads currently but my last one did it with stock 1.5. Did a master reset..... still does it. Tried to get a screen lock app off of the market but they just force my screen to stay on. Any clue???
YouTube - Behold 2 Flaws
Yeah if I reboot it stops but if I make a call to my voicemail or 611 it happens all over again. I am perplexed.
Download Task Manager from the market and then make sure all the apps are selected, and kill them all.
This will cause everything to reset and it will work.
This is what happened to me:
I would press the screen lock button and in 1 second it would wake itself up. That is when I did what i just informed you to do and it worked.
If it doesn't work, i'm sorry. You might try to reinstall the rom.
Hey thanks for the tip. I was using Taskiller and it didn't help so I went and looked for Task Manager and it worked.
