nardo89 Member Apr 1, 2013 #1 1. my search button vibrates but won't open search 2. no google play to be found anywhere ...help?
remanifest Android Expert Apr 1, 2013 #2 Install GAPPS from recovery (same way you installed the ROM) - short for Google Applicationss.
remanifest Android Expert Apr 1, 2013 #5 No, as long as you can find it on your SD Card it doesn't make a difference.
