Help on phone for 2 weeks...any way to force 3G??
Rext
Great phone, some minor issues. I can only get 3G in my office building unless I'm right next to a window. I also had to root it to get the Cisco wireless to work (Cisco).
I've had not found a LTE switch that works...if I try to use one, it stops an unrelated process. I'm not even sure how to force it thru the menu...I'm on 4.1.2, it lists Global / LTE-CDMA / and GSM-UMTS as the 3 options.
You may want to contact LG customer support.
The LG Spectrum 2 is supposed to switch over to 3G automatically if it determines the 4G signal to be weak.
