madmopedracer
Hi all
I am very new to this so hope I have posted in the correct section.
I have an Onda v10 tab which has worked very well untill now the problem is
when switched on battery or mains it starts to load android then sticks with the android logo on the screen.
I have tried the reset button no result
i have connected to the computer via usb and it shows 2 drives int mem and the micro sd card as removable drives if i try to examin them it tells me to insert a disc,on properties it shows disk full 0 bytes
as this is a china player i have no instruction so dont know what to do next
player is used for movies ebooks and mp3
should have saved up and got a galaxy
