Root [One-Click] No more need to downgrade! 10c Root (Probably all variants too)!
LitrosNub
Android Expert
hi guys, im having such a bad and hard time looking for a way to root my phone, it is a lg ms323 v10c because I need more storage space ...
the problem is that the attempt to downgrade the version 10b, but when I am installing the .kdz to 15% or 20% will stop, I'm suffering with this ...
I would appreciate a lot if anyone of you could explain this new method step by step ...
What I understand so far is that it works with the Windows tool ADB & Fastboot, I should install it (i dont know why or what for i will be installing this program, you could say me for what please?), Also install the drivers, and then apply the method in the guide of xda developers ??
But you must be in some download mode, usb debugging, or something like that?
By the way, thanks for your quick response
Does it say click close when downgrading? Don't click that box. That'll end it. That happened to me.
In fact I was investigating and i know thath the dialog box you're talking about appeared to many people but never appeared to me, or something similar, just stops, and after a while the computer says the device have been disconnected.
I think it is perhaps because it is the version from MetroPCS
but really i don't know why exactly stops, that's why I ask you some explanation about this new method to unlock the bootloader to get it rooted With the guide from xda developers ...
Or if you can tell me the correct way to perform the downgrade, and then the root .... I'd appreciate it.
Sorry man, I don't know whats wrong. Sorry.
Well man, sometime you can't but the great thing in android is that everything is possible... I already ROOTED my phone without need to downgrade, but anyway, thanks :)
