1) Download recovery-RA-nexus-v1.7.0.1.img to the root directory of your SD-Card
- Note: UnMount your SD-Card after copying these files, but keep your phone plugged in
- or don't mount SD-Card at all and push the file via adb to /sdcard
2) Save file "flash_image" to sdk tools directory:
3a) In your terminal run
adb push flash_image /data/local/tmp/flash_image
3b) if you just rooted the phone without rebooting, you can also push it to /system/bin (system still R/W) "adb push flash_image /system/bin/flash_image"
4) run
adb shell
su
- At this point, it will hang until you choose "Allow" on your phone with the SuperUser app pop-up
- $ should now be replaced with #
6) run the following commands:
cd /data/local/tmp
(or cd /system/bin if you pushed flash_image there with step 3b)
chmod 755 flash_image
./flash_image recovery /sdcard/recovery-RA-nexus-v1.7.0.1.img
