one M8 mic not working - weird ticking noise
Jimbobtx3
Hi folks,
I 'd like to know if anyone thinks this is hardware or software related.
My mic randomly stopped working. When you make a call, the other person hears a digital ticking sound.
This is where things get weird,
-When you record a video, you get the same ticking sounds
-If I dismantle the phone and remove the ribbon cable for the bottom speaker, the ticking noise is gone when I record a video. If I play a previously recorded video that made only ticking sounds there is suddenly an audio track
- If I make a call with the lower speaker ribbon cable disconnected I still get only ticking sounds on the other end (yet I can record video perfectly)
I have now replaced the bottom speaker. No improvement.
- When my alarm goes off in the morning, all I get is a ticking sound
- If I use the stopwatch or play music, I get audible normal sounds
WTF.... so do you believe it is hardware or software related?
I recently replaced the usb port. I'm unsure if this had anything to do with it.
Thank you.
