window licker
One x screen started to occasionally freeze on unlock screen (volume buttons worked also the volume pop up came on so screen itself not frozen just couldnt touch input i presume) but would fix with either a full power down or a few presses of the top button. Over the course of a day or two this has progressed to virtually always freezing and finally to where i couldnt unfreeze it even after powering down.
Did a factory reset which did give me access to my phone again but still the problem persists.
From my research it could possibly be some sort of cache problem. Also noticed after factory reset with no apps or data installed, apart from the preinstalled ones, am using 4.7 gb of internal memory with only htc sense running. this seems excessive to me but never checked it before so not sure if this is about right. If not then the cache theory could be right.
So can anyone help me please.
