Do you use a HTC car charger?
Harry
It'd matter if you're running an app that needs a lot of amperage, like a navigation app.No. Why would that matter?
Does this charger have a replaceable fuse? And is the socket's fuse in your car ok?
Only a modified car charger like HTC's would deliver enough amperage for that app AND for charging your phone
You don't use such apps in the car?
Then you'd think of that your car charger might have a defect (or bad electronical design) that might have wrecked two phones of you.
Harry
Had you a close look at the phone's microUSB port for fluff, dirt or bend pins?
You said the charger charges an other phone fine. With the same USB cable?
Harry
Tried another battery?
AgainAgain, the problem is NOT in the car or the cable. Interestingly, the phone would not charge this morning, but it would charge this afternoon. Strange.
Had you a close look at the phone's microUSB port for fluff, dirt or bend pins?The battery is not user replaceable.
That's a matter of interpretation![]()
AgainHad you a close look at the phone's microUSB port for fluff, dirt or bend pins?
Harry
Apple deserves extra censure for starting this insane trend.
Though Apple's batteries are rather easy to replace![]()
And I'm not exactly sure if it really was Apple to start with that. I'm pretty sure there might be other manufactures that did some of this BS before...
Some skills required, that is![]()
That's why I love the old phones... No instructions needed, only a screwdriver...
