I loose my wifi connection even though it is set to on and when I go to settings and press wifi my screen goes black and I get a android stopped warning.
I cannot scroll up or down on my settings screen, any ideas anyone?
it sounds like you should consider doing a factory reset. This often will help with random bugs on a major update (assuming you've recently updated to android 4.1 jellybean)
I have done a Factory Reset, looked to of worked then it started again so no joy with that unfortunately. The phone came with JB already on it but it did update to 4.1.1 from 4.1 It is also running HTC Sense 4+ or so the phone says.
