Root oneclickroot does work!
icebear8
just flash the root-zimage in knights guide and then use zergrush and thats it you will have super user and busybox! i did this on my phone and it works!
Hi icebear8!
Do you mean that this method that you linked works? If so, I will ensure to get it added to our "All Things Root Guide" sticky.
Cheers,
D-U-R-X :)
EDIT - it looks like it has already been linked in the sticky I mentioned - no need to reply!
Of course it works after you install the kernel, oneclickroot is just installing the su binary for you since you already did the hard work by installing an insecure kernel.
Oneclickroot works by looking for an exploit, running it, then logging into adb and getting root access. Since adb is already running in root mode, it will proceed.
Try running oneclickroot without the insecure kernel and let me know if that works for rooting it.
When i type into the command line it wont install the root-zimage it says the phone is ready but it just shows a bunch of words and stuff NVM I GOT IT
