Help Oneplus 8 pro fingerprint not working
Julayou
My fingerprint configuration not working :/ He doesn't recognize my fingerprints.
Have you any idea or propotition?
8Dtn0VC
If you can't register your fingerprint then there's an issue with the fingerprint scanner, which is hardware related.
Otherwise try a factory reset of the device.
Well, have you tried going to your security settings and enabled it from there? It's not automatically going to work
Do you have a case for your device?
Maybe it's hindering it from scanning.
If not, then it's a hardware issue that needs to be fixed
Yes that's what I did but during the configuration the phone does not react
Odd, but I have seen people that their fingerprint won't register in a biometric device. Some time ago I setup a biometric timeclock for attendance and out of 40 people, 2 had to be given a numeric code. One was a RN (Registered Nurse) and his fingertips were dissolved by some chemical... Weird.
