Help Only emergency calls on lock screen
mhrf90
I bought this phone off eBay, just got it today. My guess is the fingerprint scanner is not working and the lockscreen was set to use only that (never owned an Atrix so I'm not sure if this is an option or not) I tried getting into recovery mode to do a hard reset but I only get the triangle with the little green dude inside. I was told to tap right above the search button but nothing happened... The screen is seems to be working; when I go into emergency call all the numbers in the keypad work perfectly. I have not found the Odin files for this phone, are there any? What can I do to make this phone functional again?
