open a secured WiFi ??
Umm ...
- provide the password? :confused:
- ask the operator? :confused:
Or is it because you've locked yourself out of your wlan router?
...because you couldn't possibly come here and be expecting tips/tools for cracking! :cool:
The only real way to connect to a secured network legally is by using the password. If you aren't authorized to use that network then it is probably best that you don't.
Anything else is a subject that shouldn't be discussed here.
