Apps OpenGL Cube
Render the cube at the origin, then use the GL10.glTranslatef() method to move it to the proper location before displaying it. The glTranslatef() method takes 3 float values as its paremeters and these values correspond to the distanaces from the origin to move on th x, y and z axi, respectively.
one more question, is I managed to put one square on the top of the screen, and i want to put the other one on the right side of the screen (left side is 6f,9f,0f and right should be -6f,-9f,0f) but it won't work and it stays in the middle of the screen
EDIT: is there way to put a OnClickListener on the square? thank you
Can you show the code where you initialize the opengl world and also the onDraw method? Im not quite understanding you.
Code:
private GLSquare square;
	private GLCube cube;
	private GLLines lines;
	private GLTriangle3D tri;
	@Override
	public void onDrawFrame(GL10 gl) {
		gl.glClear(GL10.GL_COLOR_BUFFER_BIT | GL10.GL_DEPTH_BUFFER_BIT);
		gl.glMatrixMode(GL10.GL_MODELVIEW);
		gl.glLoadIdentity();
		GLU.gluLookAt(gl, 0f, 0f, -10f, 0f, 0f, 0f, 0f, 2f, 0f);
		gl.glTranslatef(6f, 9f, 0f);
		square.draw(gl, 1, 0, 0, 1);
		long time = SystemClock.uptimeMillis() % 4000L;
		float angle = 0.090f * ((int) time);
		gl.glTranslatef(-6f, -9f, 0f);
		gl.glRotatef(angle, 1, 0, 0);
		lines.draw(gl, 0f, 0f, 0f, 1f);
		cube.draw(gl, 1, 0.5f, 0.25f, 0.5f);
		tri.draw(gl, .25f, .5f, .75f, 1);
	@Override
	public void onSurfaceChanged(GL10 gl, int i, int j) {
		gl.glViewport(0, 0, i, j);
		float ratio = (float) i / j;
		gl.glMatrixMode(GL10.GL_PROJECTION);
		gl.glFrustumf(-ratio, ratio, -1, 1, 1, 25);
		gl.glClearColor(1f, 1f, 1f, 1);
	@Override
	public void onSurfaceCreated(GL10 gl, EGLConfig eglConfig) {
		gl.glDisable(GL10.GL_DITHER);
		gl.glDisable(GL10.GL_DEPTH_TEST);
		gl.glHint(GL10.GL_PERSPECTIVE_CORRECTION_HINT, GL10.GL_FASTEST);
		gl.glClearDepthf(1f);
	public GLGameRenderer() {
		square = new GLSquare();
		cube = new GLCube();
		lines = new GLLines();
		tri = new GLTriangle3D();
I want for every square that i draw to make a listener to handle a touch event (or a click event) for it
You cant simply use an onclicklistener with a GLSurfaceView. Youll need to override the onTouch method of Activity, take the point obtained from the touch event and convert it to world coordinates using gluUnproject()
