stephenl7797
Hi, I'm new to Java and Android. I quickly put my focus to OpenGL ES 2. When my emulator (API 14.0) is running, I can go through API Demos and select BasicGLSurfaceView (OpenGLES2), the app runs and a triangle spins. When I load the project into Eclipse and build, the same program stops working in the emulator as soon as I unlock the phone and let it load, or load it from list of apps. For this reason, I'm 90% sure the problem is Eclipse building it. I've already spent 2 days trying to resolve this and it's frustrating. I've reinstalled already and have everything properly installed. This seems to be the only problem of its kind- Ive googled for hours, so probably a stupid error
Heres what I get from running the untouched sample into Eclipse
Logcat at crash-----------------
11-19 21:35:52.887: E/AndroidRuntime(556): FATAL EXCEPTION: GLThread 75
11-19 21:35:52.887: E/AndroidRuntime(556): java.lang.IllegalArgumentException: No configs match configSpec
11-19 21:35:52.887: E/AndroidRuntime(556): at android.opengl.GLSurfaceView$BaseConfigChooser.chooseConfig(GLSurfaceView.java:825)
11-19 21:35:52.887: E/AndroidRuntime(556): at android.opengl.GLSurfaceView$EglHelper.start(GLSurfaceView.java:981)
11-19 21:35:52.887: E/AndroidRuntime(556): at android.opengl.GLSurfaceView$GLThread.guardedRun(GLSurfaceView.java:1335)
11-19 21:35:52.887: E/AndroidRuntime(556): at android.opengl.GLSurfaceView$GLThread.run(GLSurfaceView.java:1189)
Console------------------------------
[2011-11-19 21:34:40 - BasicGLSurfaceView] New emulator found: emulator-5554
[2011-11-19 21:34:40 - BasicGLSurfaceView] Waiting for HOME('android.process.acore') to be launched...
[2011-11-19 21:35:16 - BasicGLSurfaceView] WARNING: Application does not specify an API level requirement!
[2011-11-19 21:35:16 - BasicGLSurfaceView] Device API version is 14 (Android 4.0.1)
[2011-11-19 21:35:16 - BasicGLSurfaceView] HOME is up on device 'emulator-5554'
[2011-11-19 21:35:16 - BasicGLSurfaceView] Uploading BasicGLSurfaceView.apk onto device 'emulator-5554'
[2011-11-19 21:35:16 - BasicGLSurfaceView] Installing BasicGLSurfaceView.apk...
[2011-11-19 21:35:49 - BasicGLSurfaceView] Success!
[2011-11-19 21:35:50 - BasicGLSurfaceView] Starting activity com.example.android.basicglsurfaceview.BasicGLSurfaceViewActivity on device emulator-5554
[2011-11-19 21:35:52 - BasicGLSurfaceView] ActivityManager: Starting: Intent { act=...
