MrB206
Android Expert
Anyone else using a VPN and encountering issues when trying to use the OpenVPN protocol?
I use Private Internet Access and they just released an app, but I'm encoutering an error where 'tun' isn't being properly established.
The error in question is:
[HIGH]
04-07 09:27:13.661 E/VpnJni (507): Cannot allocate TUN: Bad file number
04-07 09:27:13.661 D/PIA (12210): Failed to open the tun interface
04-07 09:27:13.661 D/PIA (12210): Error: Cannot create interface
04-07 09:27:13.661 D/PIA (12210): On some custom ICS images the permission on /dev/tun might be wrong, or the tun module might be missing completely. For CM9 images try the fix ownership option under general settings
04-07 09:27:13.661 D/PIA (12210): P:ERROR: Cannot open TUN[/HIGH]
Here's the thing...my research shows this is related to OpenVPN and/or busybox, of which, I've updated my Busybox AND installed OpenVPN. The PIA note about /dev/tun only confuses the matter more, since I don't have a tun folder under 'dev'.
TDM/anyone... ideas? FWIW, I'm using Pacman Rom, so 4.2.2/CM10/AOKP42.
[HIGH]
rotecting socket fd 4
