Accessories Opinions on portable chargers?
pm1066
My only need for more batts with the X is on long flights, watching movies. The Chinese charger and 2 batss for $10 looks inviting, especially since I would need it relatively infrequently. The portable charges are all in the $40-$60 range, which is a bit steep.
Also, how do these things impact the battery being charged? Any potential for damage?
Where did you find a portable Droid X battery charger? I have two batteries and need something to charge one while one is in the phone.
Any suggestions would help.
I ordered it.. even if the batteries onl;y hold 2/3rds of the charge off my original battery, thats plenty for extra juice. As long as I have enough time to recharge my original, its a good deal.
I also ordered a second wall charger for the 2nd battery as well.
You can get a cheap power inverter for your car and a multi plug, and then plug two of those wall chargers into it to charge two at a time. I used to do that, and also run my phone off the car battery with the original charger all the time with our old env2 phones.
